model 3 servis
denial
Active member
2 jún 2014
612
Zdravim, vypisal som si nejake servisne ukony, ktore by niekedy bolo dobre spravit.
Ktorym by ste sa venovali prioritne a ktore su podla vas nepodstatne?
Brake fluid health check every 4 years (replace if necessary)every 2 years210 eur
Cabin air filter replacement every 2 years.every 1 year95 eur
Wiper blade replacements every year.80 eur
Clean and lubricate brake calipers every year or 20,000 km70 eur
Rotate tires every 10,000 km or if tread depth difference is 1.5 mm or greater & Tire pressure 2.9 bar
Wheel Alignment200 eur
Air Condition refrigerant 660g Kältemittel, oil POE / RB100EV , receiver dryer, desiccant359 eur
General Inspection210 eur
Front Radiators Cleaning250 eur
Gearbox oil + filter change80 000 km
12V lead acid battery changeAtlasBX / Hankook 85B24LS 12V 45Ah200 eur
Front camera windshield cleaning50 eur
Corrosion check - mud flaps, projection / puddle lights in doors
Oil door handle pivot pins ; Charge port door hinge & latch
Grease frameless windows seals, Door seals
Battery Coolant replacement ?200 000 km / 10 years ?Chemical test
Front Upper control arms, Rear Lateral link, Bushings inspection, Ball joint, Suspension
High-Voltage Battery Breather Valves (Gore Vents)
Frunk Latch and Emergency Release - test tow eyelet 12v + internal button & clean latch assembly & dry lubricant ptfe/lithium
